That is your clutch housing joining onto the back of the engine isn't it? If so could be the oil seal at the back of the crankshaft leaking, or the clutch slave cylinder.
Judging by the colour of the gunk coming out, looks more like the clutch to me.
Check the fluid level on your clutch master cylinder - is it dropping at all.
Good luck mate
Dandy Highwayman
Yup, Definately looks more the colour of brake fluid (not like gear/engine oil)
on the first pic you can see some fluid running around the outside of the housing, maybe the leaks is coming from above, is that where the cluch slave cylinder is?
Cheers guys. Hopefully get some time to have a look in the next few days, still confused as to why its only shown up now, after the car hasn't moved for a while. Still, maybe its been an issue for a while, but as the car is normally driven almost daily, its not built up enough.
Got a few other pics, but as my connection at the moment is so slow I'll not post them unless I can't get to the root of the problem.
