1 - 20 of 56 Posts
Registered Chump
once again i need to ask for your help
on top of teh gearbox all of teh shoddy bodywork the squeaky PS pump the car now pulls hard right under breaking
the right hand tyre has a lot better tread than the left would that do it?
i suspect a knackerd tension arm bush could that do it ?
what else should i look for also anybody want to lend me 10k to fix this lemmon
oh ps ill get the allignment checked again
T
Guest
Tyre tread will affect it going in a straight line when you let go of the steering wheel, Get the calipers checked for sticky pistons too. Have you got any knocking or grinding noises as well?
Normally a severe pull under braking is down to a pad or calliper sticking have a look at your discs and see if one is burnt red
Registered Chump
discs look alright, ill strip the calipers and bleed them, i have noticed the steering feels a bit loose on bumps and potholes etc which made me think tension rod but it was alright for a bit after i had the tracking done.
There is no squeaking or grinding not since i dealt with the squeaking from the bushes
T
Guest
They're the ones that come out either side of your steering rack mate. You'll need a ramp to check them.
Why would you bleed the brakes unless you have replaced pipes or burst a pipe
hey im the one asking the questions :))
surely if i remove the calipers to clean and inpect them ill need to bleed the breaks to make sure there is no air in there?
Again why would you be removing the callipers??? And no air will get in unless u have lost all brake fluid or replaced pipes.
All you will be doing is removing the wheels and using a flat screwdriver gently lever the pistons in and then see if the pads are free in the calliper as well,if the pistons take a lot of force to go backin then you will need to free them off by carefully lifting the rubber seals off just enough to spray something in there to help free them then press the brake a few times and lever the pistons back. It may take some time lol
Registered Chump
Discussion Starter #13
oh they were maga stiff when i changed the disks so they should slide in and out easy ???
They should slide in and out easily enough mate stiff but not so stiff you go Jesus Christ there stiff
Registered Chump
Discussion Starter #17
ill do the back as well then just to be sure
you guys are awesome thanks whats the best thing to lube it with ive got spray grease that says for breaks but i bet there is something better ?
hope it works :)
on the plus side just got a pay rise so should see and extra 200 squids a month to help pay for all this :))
Because they could have been removed and not bleed?
Most logical answer as it's not braking
Tapatalk - S3 rooted
but they are braking hence the dive one way if the callipers were not bled there would be no brakes at all no pull no stopping just pedal straight to floor mate :)
hope it works :)
Use a fluid that will free of seized parts only no need to grease up after it since the rubber boot will protect it lol
Registered Chump
Discussion Starter #19 (Edited)
WD40 then .... which is made of fish i found out
i wish you didnt live so far away you are well helpful id happily give you some beer tokens to have a look over the old bird
gota sign off the mrs can feel teh baby kicking for the first time :) :) :) :)
Don't drink beer mate :) and enjoy the baby kicking mate :bigthumb:
1 - 20 of 56 Posts
