i think i have found my problem, my new r33 seems to have a r32 gear box on it. it has the wire under the car that should plug on to the gearbox but no were to plug it as it hes the cable type conection on the box that r32 have the cable has been cut off but the end is still threaded in to the hole.
whet i need to know is can i screw a r33 transducer in to the hole were the r32 cable would go and then connect the plug up to it to make the speedo work?
If it is an R32 box then I am pretty sure the R33 sender will fit in the cable hole.
I have not seen a R32 box but the R33 sender sure looks like it was a hybrid to fit a sender in a cable drive output.
Andy.
thank you mate , any idea were i can get 1 from?
