Especially T.F.S. or andy42uk as I've read your posts and you guys know your way around these motors better than anyone.
I am currently in the process of rebuilding my RB25DET, I have a set of 87mm Mahle powerpack pistons set to go in as well as a set of eagle H beam rods.
1) What should my piston clearances be, they didn't send that in the box! A website I went to said .005inch or .127mm. Is that the total clearance? total Bore size 87.127(.0025 Per side) or the clearance to one side(total Bore size 87.254)
2)nd question I am about to buy rod and main bearings, is standard size ok?
3)I wonder how much it would be to post my motor and all parts to you, My mechanic here is pretty good but the closest thing he has done to an RB is rebuiling a nissan patrol rd 28, the blocks look Identical! so I wonder if with differnet pistons, it might work as a stroker kit?
Thanks in advance guys.
Glenn
Glenn
