Can you get shrouds for them to stop the reflection on the windscreen?
It's annoying!!!
cheers in advance!
Not sure where to get them but they do exist! In the meantime you could just turn the brightness down on the link controller.
haha i bought three defi style gauges for £120 of ebay and they come with everthing senders/sandwich plate/sensors my only issue is gunna be fitting them doh,which is the acc wire and the lamp wire on the gtst? il put up a help post soon if i get too stuck:) but from what i can see the gauges look cool without the front cap cover.yes i know defi 1s are best.
Defi style? What are they really? To be honest it doesn't matter, if the gauges give accurate readings then who cares? Gauges cost as little or as much as you want really. I've got Defis but they wire up through the link controller so I can't help you. But there must be a previous post about which wire is which.
You can do that??? lol.
HOW??
Just press the down arrow on the link controller when the car is switched on. There are about 4 different settings of brightness and it just cycles through.
