Dorset/Wilts Area Rep
Can you give me a quote on the following please:-
All for R33 GTS-T RB25DET Spec 2
T3 Manifold to Turbo gasket
Uprated 1.9mm MLS Head Gasket
Uprated Exhaust Manifold Studs x 12
wideband lambda flange weld on
Set of Camshaft Oil Seals
Rear Subframe Poly Superpro Bush Kit
Steering Rack Poly Superpro Bush Kit
Lightweight Alloy Wheel Nuts x20 Red
Uprated Head- Exhaust Manifold Gasket
Uprated Head- Inlet Manifold Gasket
Thatcham Appr. Locking Wheel Nuts
RB25DET Gen Nissan Turbo Elbow Gasket
Genuine Nissan Oil Filter
Gen Nissan Rocker Cover Gaskets
Turbo Pair HKS Decat Gaskets
Elbow to Downpipe gasket
A few things I've added, like the wheel nuts I'd like, but proabale dont need lol.
Stu
Hi there and thank you for the enquiry...
As you may have some items on a 'wish list' basis, it may be better if you call us direct on our Freephone number during office hours.
Or PM me your contact number and a convenient time to call and I will get in touch.
Whichever way I will try to give the best price possible for a package deal ; )
Regards
Chris
OK
Stuff I am def going to need:-
Just a few questions can I get:-
Uprated 1.8mm MLS Head Gasket
and do these come with nuts and washers
cheers stu
Hi Stu,
thanks for the nice list :bananadie:
Here are the prices for each item and I will sort out a nice discount on the total price :)
T3 Manifold to Turbo gasket: £ 19.49 ( Genuine Nissan recommended unless you have an aftermarket stainless manifold)
Uprated 1.9mm MLS Head Gasket: £224.99
Uprated Exhaust Manifold Studs x 12: £54.99
wideband lambda flange weld on: £6.99
Set of Camshaft Oil Seals: £17.99
Uprated Head- Exhaust Manifold Gasket: £44.99
Uprated Head- Inlet Manifold Gasket: £24.99
Thatcham Appr. Locking Wheel Nuts: £17.99
RB25DET Gen Nissan Turbo Elbow Gasket: £23.99
Genuine Nissan Oil Filter: £9.99
Gen Nissan Rocker Cover Gaskets: £27.99
Turbo Pair HKS Decat Gaskets: £12.99
Elbow to Downpipe gasket : £12.99
Uprated 1.8mm MLS Head Gasket: The uprated MLS is imperial size so 0.071 thousadnths of an inch...this works out at something between 1.8 and 1.9 so should be fine.
and do these come with nuts and washers: No the set of nuts are £11.99 and the washers are on their way to us so wont know for a few days price on those.
Total £ 512.36 plus insured shipping £15.00 so Grand Total £ 527.36
We can do a delivered price for £475 all in , 10% off :bananadie:
How does that sound Stu?
Chris
:cheers:
OK
cheers stu
Hi Guys,
Going to start on the exhaust side now. Snapped studs have twisted my arm so going to need to order these bits asap:-
T3 Manifold to Turbo gasket: £ 19.49 ( Genuine Nissan recommended unless you have an aftermarket stainless manifold) Yes got a stainless manifold going on.
Plus nuts and Washers
Plus do you do heat wrap. Going to do the turbo elbow and downpipe.
Let me know how much and I'll get payment sorted straight away
Regards
Stuart
