R32 GTR alarm/remote starter wiring info
15K views 3 replies 2 participants last post by  Tosseef Kaira
#1 · (Edited)
Alright you guys, I've scowered the interwebs for the info to install an alarm/remote starter into my 1990 R32 GTR with no avail. All I've seen is people saying take it to a shop, blah blah blah. Screw that, I've been installing these things for 20 years so here for your viewing pleasure, I've done the hard part for you. Enjoy.
And as always, this is just a guideline. Always test your wires prior to making your connections.
1990 Nissan Skyline GTR
12 VOLT +...............WHITE/PURPLE.................IGN HARNESS (CAR SIDE)
STARTER 1 +............BLACK/WHITE..................IGN HARNESS (CAR SIDE)
STARTER 2 +.............BLACK/YELLOW................IGN HARNESS (CAR SIDE)
IGNITION +...............BLACK/RED.....................IGN HARNESS (CAR SIDE)
ACCESSORY +............BLUE.............................IGN HARNESS (CAR SIDE)
PARKING LIGHTS +......RED/BLUE.......................HARNESS TO SWITCH OR DKP
HORN -...................GREEN/WHITE...................STEERING COLUMN HARNESS
BRAKE +..................RED/GREEN.....................SWITCH OR DKP
DOOR LOCK..............ADD ACTUATOR.................IN DRIVERS DOOR
DOOR UNLOCK...........ADD ACTUATOR................IN DRIVERS DOOR
DOOR TRIGGER -.........RED/WHITE.....................DKP
TRUNK TRIGGER -........PINK.............................HARNESS BEHIND UPPER REAR SEAT
E-BRAKE -..................LT. PURPLE/ORANGE?........AT SWITCH
TACHOMETER
I didn't have to find the tach wire as my remote starter has virtual tach and doesn't require the wire to be connected.
Hope this info helps out other DIY'ers that have been looking for the information.
