1 - 11 of 11 Posts
Hi. Can anyone tell me what size cc injectors it uses and what all the gear ratios are please. Thanks :)
Discussion Starter · #4 ·
poo. got a program that gives you a dyno plot when you connect a laptop to the car. need to input a few values first.
Why are you asking the size of an R32 injectors etc when you have an R33?
You will find theres a difference between gearing and injector size i belive depending on RB20DET or RB25DET engine is fitted.
RB25 gearing
Gear Ratios Maximum Speed in Gears (* theoretical)
1 3.214 62 km/h (38 mph)
2 1.925 104 km/h (65 mph)
3 1.302 154 km/h (96 mph)
4 1.000 200 km/h (124 mph)
5 0.752 266 km/h (165 mph)*
Reverse 3.369 59 km/h (37 mph)
Final 4.363
Discussion Starter · #8 ·
because i can use this software on a r32 rb20 as well :)
Discussion Starter · #9 ·
thanks for the info though wiscobandit, see you sunday :)
Discussion Starter · #11 ·
its free from the web :) just have to put in some info ( injector size, gear ratios, rev limit, weight, weight split and a few others ) its may not be 100% correct but it would give you proof if a new bit you just fitted gave you any power gains :)
1 - 11 of 11 Posts
