I have searched the internet and cannot find a definitive answer on what the wheel stud knurl sizes are. Would anyone here be able to answer my question? I am looking for the knurl size for the front and rear wheel studs. Thank you in advance!
Not sure about the GTST but a typical knurl size for a 12mm stud would be around 12.84 mm but you would need to check the hub stud holes to be sure of getting a good interference fit.
so my fronts were measured at 11.5mm, would it hurt if I ran a 12-12.84mm knurl size stud?
Are you sure of those sizes? The fronts are way bigger than that.
12.8mm sounds right for the rears ;)
We stock both fronts and rears if needed....
