1 - 2 of 2 Posts
Dandy Highwayman
bit of adumbass question but...
where's safe to use a trolley jack on a r32? the nissan scissor jack uses a hardened bit of sill but you cant use that for the trolley.
any suggestions?
Old Member
Check where the subframe picks up on the chassis for jacking the rear, the front end can be jacked using the box-section which runs the length of the passenger compartment. Obviously, chock wheels on opposite side and use axle stands to support car after jacking up...... don't want to loose any members do we !!!
1 - 2 of 2 Posts
