Hi guys, so i have an r32 gtst and i have a weird problem.
So when i turn on my lights onto the low beams, both low beams turn on however after maybe 2-3mins the drivers side low beam will turn off all of a sudden. The parkers and the high beams on both sides will continue to work even though the drivers side low beam has turned off also.
I have replaced both globes, fuses, even new wiring harness and I'm having the same issue. Was wondering if anyone has experienced the same issue or would know what else to look for/replace.
Not being an expert in any way it sounds to me as if there is a relay breaking down
Cheers, might try and replace that next however when i remove the relay the headlights still work and the same issue happens
