1 - 12 of 12 Posts
go NB,or go home
hello guys,can somebody tell me,what type clutch has my car?cause i find a lot different info on the net,is it push or pull type?does some other Nissan clutch fits me,like SR or CA or ZX?there is big choise of stronger clutch sets available,but i dont have oportunity to take away mine to check how it looks,once thing i know,that is needs to be changed,cause its a bit hard to find clutch for Skyline in my country.I found some info,that NA have gearbox the same as S14,by that info i even fitted S14 shortshifter,cause one thing i know,that it doesnt fit from DET.Am i right?Thanks in advance
Check FAST - it will tell you if you have a push or pull type clutch. I have a 95 R33 and my one is a Push but it can be either. If you can't get FAST ask a trader on here like Conceptua, they should be able to do it for you and they can usually get hold of a blueprint OEM type clutch.
go NB,or go home
1 - 12 of 12 Posts
