Aftermarket Bits
Parts are for GTST
LPG
LPG Conversion Kit, Included everything (all injectors recently reconditioned and filters replaced), Tank and fittings (Fits in spare wheel well), Pipe work, ECU, Programming Cable, Reducer, Injectors, PreDrilled Manifold. (Only item you may need to purchase to fit would be P-Clips to hold the pipe to chasis rail, which should only be a couple of quid). 300
Info Here ... http://www.skylineowners.com/forum/showthread.php?t=135764
Exhaust HKS Hi Power - £300
Big Brake Kit (similar to DB power kit), inc 345mm Front Grooved and Dimpled Discs, Caliper Extension (may require extended brake lines), GTST Calipers in Red, Fully Rebuilt with new Seals only 10months ago. Rear Discs Grooved and Dimpled. Rear Calipers. Full set of Yellow Stuff pads all around. Used but plenty of life left in them. (Likely require at least 18" wheels on front. - £325
Wheels Manix Vortex 18" Staggered, Light Curbing Pics Below, Rear Tyres less than 1000miles Front Tyres on limit due to edges - £425
