Just wondering if any of you guys have had a similar problem:
My front right wheel has -3.4 deg camber and I can't figure out why (left side is only 1.5). The car has all standard arms, non of which look to be bent.
Someone suggested to me that one of the bolts holding the upper arm to the chassis could be bent. Has anyone heard of this? My other thought was maybe the bushes in the upper arm are stuffed and have collapsed?
If I can't find out whats wrong, I'll just have to throw a set of adjustable arms at it :rolleyes:
Belgium/Netherlands Area Rep
maybe your car has been in an accident in its previous life
check for things out of alignment, kaput, bent, whatever, you get the idea
Yeh, that had occured to me.
I've checked as much as I can without having put on a jig etc. All the panel gaps look fine, and there is no sign of repairs etc to the chassis.
I suppose its still possible, but maybe I'd rather not know :rolleyes:
I ordered some adjustable arms anyway :bigthumb:
get it checked with a 4 wheel alignment, if the tracking is out that will affect the camber, i didnt believe it until i went through it with the guys doing the alignment, or it could be a fooked bush bud
