Hi everyone,
Car's giving me grief again and I'm struggling to pin point the issue.
It starts and then stalls on the first key turn (attempt).
Then if I start it again and give it some throttle, it runs very rough and needs to sit at around 1.8k rpm, otherwise it stalls.
After it's warmed up it runs like it does normally.
I've taken a video of the car at start up on the Sensor screen of the PFC and again after a good 70 mile trip.
I was wondering if this was due to me having starting issues and the battery being not fully charged. I tend to use my car a few times a week, but I was away for a week and then this issue started. I was wondering if it was due to the drain on the system with all the aftermarket gauges and alarm system etc. From what I understand the car won't charge up a for example 70% battery back to 100%, it will maintain it at 70%. I'm going to try and start it with a jumper pack connected to see if it just fires up and runs fine, as I'm thinking that maybe the battery draws so much to initialise the first running of the car, that it's slowly killing off a weakened battery.
I've had new plugs and it's got splitfire coil packs. Could this be an injector or ignition pack issue? It's the fact that it runs fine after a bit of warming up that is confusing me over where to look, but to me, points me towards a cold start issue. The fuel pump is about 2 years old, HKS, so I'm not looking at it being that. It's got larger aftermarket injectors. When running the alternator says 14.6/7v when cold and runs about 14.2/4v when driving depending on if lights are on etc.
The other week it wouldn't start, so I cleaned the plugs, repaired a leaking fuel filter with new fuel filter and new fuel pipe and double/triple checked all the hose clips etc. Then we jumped it with the power pack and it ran not a problem. The battery is about 3 year old and is a big heavy duty Halfords one for an R34 GTR. I'm guessing that if it starts well from power pack then it means that I need to charge the battery, and if after a while it happens again, its new battery time, yeah?
Any suggestions or tips and advice I'd love. PS: Can you charge the R33 GTR rear mounted battery from the connections in the engine bay by the fuse / jumping points?
I can't think of anything else that would help. I thought that it was the 02 sensors as does run rich, which I will be sorting with a remap, and I thought that these could be coaked up, but the voltages read 0.02v at cold and 0.80v when driving and dip to about 0.63v when you're driving and take your foot off the throttle.
I also don't do any short trips, I tend to do long runs in the car, so no just nipping to the shops etc. It tends to always be round trips going out between 10miles to 80miles and back, which from what I understand is ok for the battery, as opposed to lots of 4mile trips where it never warms up etc.
Just after starting
http://www.youtube.com/watch?v=t_y4G707RPM&feature=youtu.be
After long ride out
http://www.youtube.com/watch?v=RbKbAbsiESs&feature=youtu.be
