Im planning on swapping my R33 GTS Type X in the future and was wondering where I should get these parts from. Like trusted brands and best parts to use.
Gearbox and shifter
Gearbox crossmember (not sure my auto fits)
Driveshaft (front half)
Clutch pedal + lines
Slave cylinder, master cylinder
Brake pedal
pressure plate etc (clutch kit will be easier)
Flywheel
Spigot bush (I think)
There is probably more
If there is anything missing or if there is a forum that can guide me through this that would be amazing if I can get a link. Im just new to the whole manual swap sorry.
Discussion Starter · #2 ·
I found a little more parts if someone can tell me if this is correct
Rb20 Trans and Rb
s13/14 Trans mount
s12/14 KA Manual pilot baring
240 Slave
Longer bolts for flywheel and trans
Clutch/flywheel
Wiring work (bypass neutral safety)
I know JDM garage do a kit for manual swaps which include everything other than the wiring loom i think
