1 - 8 of 8 Posts
violence IS the answer!
Reet then, ive just bought an auto rear diff for my manual R33 GTS-T but the diff is from an ABS model but my car aint.
So i was told that if i got a prop saft off an auto with the same ABS diff that i would be ok to put them both on mine.
So im in need of an auto prop shaft, and as cheap as possible too pleeeeaaase! :cheers:
Cheers pal.
P.M me your full address and rough weight of the prop shaft and ill get a price on a courier and if it aint too expensive then ill have it mate.
on a abs car the diff is longer. make sure you get the back bit too festa from the abs car. im sure you could get a rear half from a manual car too as when you change auto to manual its the front bit you change. so i reckon the rear part from a maual or auto as long as its a abs one should be fine
1 - 8 of 8 Posts
