need to know the standard specs of a gts-t please, just throwing together somthing to put in my window at northeast motor show
top speed
kerb wieght
0-60
0-100
displacment
etc etc i know they will be on here somwhere but if anyone can lay there hands on it quickly it would be appreciated
gtst 93-97 £4000-£14000 2498cc 250bhp 0-60 in 6.7 sec top speed 152
thats just taken from fast car magerzine so dont know how reliable it is
hope it help abit tho dude
max power says :
2499cc, bhp 247,wieght 1501kg, 0-60 6.2, top speed 153
once again hope this helps
Always sideways
Curb Weight 1390 Kg
Length 4640 mm
Width 1720 mm
Height 1340 mm
Wheelbase 2720 mm
Turning Circle 10.4 m
Chassis & Body
Body Type 4 door saloon or 2 door coupe
Layout Front engine/RWD
Wheels F/R 16 x 6.5 JJ
Tyres F/R 205/55 R16 or 225/50 R16
Brakes Ventilated: 4 pot front, 2 pot rear
Steering Rack & Pinion (front) HICAS (rear)
Suspension F/R Independent multilink
Engine
Type (see below) RB25DET Twin cam, in-line 6, Turbocharged
Displacement 2498 cc
Compression Ratio 9.0:1
Max. Power; kW/HP 187/250 @ 6400 rpm
Max. Torque; Kg-m/ft/lbs 30.0/213 @ 4800 rpm
Bore x Stroke 86.0 x 71.7
Redline 7000 rpm
Fuel Injection Nissan EGI (ECCS)
Fuel Tank Capacity 65 litres (14 gals)
Fuel Super Unleaded (97 octane)
Performance
0 - 100 km/h (62 mph) 6.96 s (approx 6.74 s, 0-60 mph)
0 - 400m 14.30 s
0 - 1000m 26.91 s
Top Speed 266 km/h (165 mph)*
Drivetrain
Transmission 5 speed manual
Gear Ratios Maximum Speed in Gears (* theoretical)
1 3.214 62 km/h (38 mph)
2 1.925 104 km/h (65 mph)
3 1.302 154 km/h (96 mph)
4 1.000 200 km/h (124 mph)
5 0.752 266 km/h (165 mph)*
Reverse 3.369 59 km/h (37 mph)
Bad Ass Mo Fo!
was going to say, top speed 150 is not very accurate as they defo can go faster.... 165 is more realistic.
