1 - 11 of 11 Posts
Hi guys I just bought a 1996 GTS25 and there are a few small issues I want to get sorted.
First of all it uses a lot of fuel I filled the tank and when it was half empty I had only traveled 140kms and that is not thrashing it just normal daily driving.
It is hard to start when warm (It takes a few more turns to start) so I think it might be suffering from vapor lock so I need to get the FPR and injectors tested.
Other then that I think it just needs a good service the engine sounds nice no ticking or knocking apart from the slight tick from the injectors.
It has a auto box in it that holds gears for too long sometimes but im not worried as I hope to replace it with a manual box.
Also 1 other question is it normal for these cars to decelerate faster then other cars?
Thanks for taking the time to read this and for any help given :)
Firstly, welcome aboard :bigthumb:
Where abouts in the world are you?
Vapour lock isn't common and only happens under very certain circumstances... what makes you say it's that?
Your symptoms more point toward a faulty O2 sensor and/or faulty water temp sensor. I'm leaning toward the latter more based on the fact you've said it's hard to start when warm. If you're not sure where that sensor is, look where the top radiator hose joins the engine - around there you'll see 2 small sensors. One is a 1 pin sensor, the other is a 2 pin sensor. 1 pin = gauge. 2 pin = ECU. You'll need to replace the 2 pin sensor.
I honestly didn't know there was a "normal" deceleration rate... every car will be different based on compression ratios, aerodynamics etc etc :)
Thanks mate im from New Zealand :)
I just assumed it was vaporlock and was going to start by testing for that but thanks for the advise I will test the sensor as soon as I can. Is there a certain resistance it should read if I use a multimeter to test it?
Ah another Kiwi :bigthumb:
Not too sure what the best testing method is... but it is a "wear n tear" type part so it's probably easier to just replace it. Won't cost much money either :)
Water temp sensor is resistance based so test for that, I.ll see if I can find the figures, if faulty it will keep the engine in cold start mode so use a lot more fuel,
I think its just as likely to be the O2 sensor, as this controls fueling full time as its N/A so stays in closed loop until full throttle.
PS Welcome to the forum.
That sounds about right I will see what I can test for with the multimeter. Can the o2 sensor just be disabled like you would if removing the cat?
Cool I Will give that a go. Where abouts in NZ are you?
I'm just another Aucklander lol.... on the sunny Hibiscus Coast though. Where abouts are you based?
No, if faulty or removed the O2 sensor will cause the ECU will over fuel full time, on the N/A its the major component that controls fueling.
Ok so I checked the ecu for faults got code 55, I reset the ecu took it for a drive and tested again still no errors. I am going to service it with new oil, oil filter, fuel filter and might as well replace the temp sensor just incase it is faulty.
Does $57 sound about right for the temp sensor?
I'd have thought they'd be cheaper but in saying that, I haven't needed to replace one yet lol so not a clue what they are actually worth. If that's a price from Repco, go elsewhere... their retail prices are a joke!
1 - 11 of 11 Posts
