1 - 3 of 3 Posts
as above pretty much standard car, has FMIC but standard turbo,actuator and boost solenoid but once you give it throttle it will overboost and hit fuel cut ive seen it hit 15psi by the time i had let off?
have changed the actuator still no difference
also while the actuator was off i checked to make sure the waste gate was opening freely and not seized so theres no reason why the actuator shouldn't be able to open it?
car is a 1996 spec 1.5 gtst
check the vacuum pipe that runs to those bits. Alternatively check that the actuator isnt cracked.
I had the same when my bleed valve cracked.
1 - 3 of 3 Posts
