Autobahn Burner
has nylon blades on the exhasut side if i remeber corectly could be wrong :S
No
Spec1: steel intake wheel:ceramic exhaust wheel= : semi poo
spec 2: nylon intake: ceramic exhaust = complete poo
If you break the exhaust wheel on a spec 1 it will fly out of you exhaust pipe (hopefully not skewering the driver behind you) if you have a decat. or will get caught up in it if you do.
A spec 2, the nylon wheel can shatter raining bits of nylon all over your valves and cylinders. but it spools faster.
Get an aftermarket one full steel mate.
