Hi, new to the forums but i feel this is the best place to get experts advise on the product
So i appreciAte the time you take to read this
Ive recently brought a 1994 R33 Gtst (If providing plate numbers helps let me know!)
After leaving it to sit for about 1 month i disconected the battery, i got lazy re attaching the main battery power terminal and had it on loose (rather the copper lume)
After driving the car the cars cut out because the batterys come loose.
I only mention above as ive only had the problem since then!
after that incident and re attaching the battery my vehicle will now start run for maybe 10 seconds and stall. First inital thought was a damaged tps although i cant be sure and dont want to dish out the money if its not the problem.
Ive read through forums and followed all idle issue posts The common dirty aac valve which ive cleaned and put back however the car will still idle then stall after start up.
Please assist me on what steps i should take next
And again much apprecaited!
