My mate's Skyline is refusing to start.
It cranks well, has a spark while cranking and fuel pumps past the filter into the rail but it seems there is no injection.
I've done a quick check of all the sensors to see if any are loose etc and they're all there.
It has an immobiliser and the light stops flashing when the fob thing is pressed onto it.
The 'CHECK' fuel pump-shaped light comes on as soon as the ignition does and I think stays on while cranking but obviously the pump is working because fuel is getting to the rail and I can hear it priming. Whilst cranking another light comes on below it which looks like a block with 4 S's above it - possibly the immobiliser light?
Immobiliser fault?
Also yesterday after returning the key back from the cranking position and onto 'key stage 2', the engine seemed to kick-back a couple times with delays in-between and cough the wrong way a rev or two :wtf:
P.S There is currently no A/C belt on it and I just changed the rad and fan because he hit an owl and punctured the last one lol. The original temp sensor isn't connected and never was but surely none of these affect it not firing?
It hasn't moved from the last time it was started (a few days). He said it started normally last time but he had a couple misfires and has been for a few weeks until it's warm, but that could be a load of crap because he's not very knowledgeable about cars...
Thanks for any tips...
Immobiliser fault?
