can any one please tell me what the difference is between an r33 gts spec 1 head light and a spec 2 head light and could a spec 2 light be moded to fit a spec 1? thanks: wave:
so if i wanted to fit them and covert my spec 1 front end into a spec two could it be done and what would i need to get and change? and has any one ever done this? :notworthythe diferences are slight but involve the shape of the lense so no youcant really mod a spec2 light into a spec 1 however ..you can fit em interchangably, so long as the bonnet is of the same either spec one or two..as the leading edge of the bonnet where it meets the light has a different radius. essentially they are the same (i believe) wiring wise . diferent beam pattern perhaps, due to different front lense.
look out for the spce 2 from the four door ...completely different wiring.
