1 - 11 of 11 Posts
ok !! i have r34 calipers on my r33, but i now need to change disks and pads so my question is can i use r33 disks with the r34 calipers n pads or do i need the r34 disks??
im asuming they are r33 disks on at the mo as i got r33 standard wheels and r34 disks are bigger?
maybe im wrong i dont know if some 1 has the knowledge please share :)]
just add its a gtr not gts if that makes a differance
You'll need the GTR discs and pads mate. I think the R33GTR and R34GTR discs are the same size.
i was told that the disk were different , as the r34 came with 18" wheels to fit the bigger disk ??
cheers for your thoughts tho vizible
How many pistons on the R33 GTR calipers ?
im not sure but i think th 34's have 4 pistons
R33 GTR has 4 pot Brembos. :D
you know more than me dude , wot do the r34's have,
and just to confirm, if any one else see this also
i can go get my r34 pads and r33 disks all good, no probs ?????
Chairman Stagea Owners Club
R34 calipers (the gold brembos) can be used with 17" wheels as I have them on my Stagea .The r34 GTR calipers have bigger body than the r33 ones so could hit the wheels if the offset is wrong. Spacers would solve this though.
I thought that the R34 discs were larger but could be wrong.
One thing however is certain they have larger caliper bolts than the r33. This can be got over by fitting inserts into the calipers to take the smaller bolts.
The pads are not interchangeable .
360 TAG: vizibledog
From EBC's website
R33GTR Discs
Type : Vented
No of Bolt Holes : 5
Diameter : 324
Height : 54
New Thickness : 30
Minimum Thickness : 28
Wide aperture grooves
Special disc alloys UNIQUE to EBC
Dimple hole construction
Balanced geometry
R34GTR Discs
Type : Vented
Diameter : 324
Height : 54
New Thickness : 30
Balanced geometry
1 - 11 of 11 Posts
