Hey guys,
Will be having a full service done soon, but I want to supply my own parts.. A: As I want to choose what goes in, and B: I'll probably get the parts cheaper....
Car is: R34 GTT , near enough standard, apart from Kaki Exhaust and Trust intake.....
History:
Am 1st UK owner in May... Car Had Oil change done (5w40) and new set of Coilpacks. Mileage 100k
I need: Oil & Filter, Fuel Filter, Cabin Filter, Brake Fluid, Coolant, Spark Plugs.... Un-decided as to whether to buy Gearbox oil and have that changed... (Have done 3k miles since purchase)
I have Motul 5w40 5ltr oil already....
I plan to buy Oil/Fuel Filter from Nissan. Do you guys know the part number for those, or what other car those parts are used on? As sometimes, the Parts guy ain't always switched on.......
Cabin Filter - Done some research, the best I could find that appears to be an exact match, would be to use the same Cabin Filter that fits the: Nissan Maxima QX MKII (2000 - 2003)
I think I got to that car by finding the part number used for the Cabin Filter, and then using cross-ref to find non-oem parts, which lead me to part number: ADN12507 (Blueprint), and then seeing the Maxima QX as a match ?
If you got suggestions, please send my way !
Spark Plugs ? I used to use: NGK BKR7EIX in my S14a.... I prefer to stick with NGK plugs, so given my lack of mods, whats the ideal plugs to use ??
Brake Fluid ? - Just normal dot 4 fluid ?
Coolant ? - Any coolant ok to use ? (say eurocarparts stuff ? ) . Skyline is not my daily......
If I were to buy gearbox oil, what brand/grade have u guys used before ?
My Car:
History:
My Car:
