Hiya, could you explain what the "engine smokes badly, due to High boost det ring lands probably" means? what are the damaged parts that will need replacing?RB 25 DET engine smokes badly, due to High boost det ring lands probably,
still ran with good oil pressure and water temp.
Should be coming out this week, on an Auto so not thrashed, mileage 55K.
No ancilliaries....long block only (Head and block) £275
I think they should make Dibs outlawed...Andy / Martin
Someone has already "Dibs" it, if they dont have it i''ll work from down the list
