My rb20 ac compressor went out, and the belt snapped.
I'm having a hard time finding a decent replacement.
What is a direct drop in compatible ac compressor and belt that I can use?
And is easily resourced.
Thanks.
It's not just a skyline, it's family
Thanks.
I have two ac compressors and belts... Only problem is i am in the UK.. I can ship worldwide if needs be.
Belt is used and ac compressor is used, but function fine.
pretty sure a 300ZX compressor will work
That'd be sweet if it does. I also heard a Nissan Quest compressor will work, but cannot confirm. You could also get a used rb20 compressor off ebay too, if you want to do the guessing hassle. I'm also looking for a compressor as mine is blowing fuses.
*Edit - I don't know if this is any help but, here is the part number for the rb20 compressor... 92600-05U00
*Edit #2 - Here is the Zexel number (tried looking up this one and found nothing) 506031-0111
yup
ok so a 300ZX compressor is not a direct replacement.... though with a little work (change some a/c lines) it could work
Same size and the lines ALMOST match up, the angle is different
going to check around tomorrow to see if I can get my old one rebuilt
will check back once I find an answer
fyi the part numbers on my stock one are 92600-05U05 (and it's a Zexel 506031-0119)
yup
picked up my compressor from the rebuild shop
they didn't do anything to it
Tested it and it works just fine.... there is another reason the fuse keeps popping I guess...
I am in search of a A/c compressor for my R32 GTS-t mine is going out and I live in las vegas anyone help me in locating one. before I drop a bunch of money on rhd japan
