I want to build my rb20det for my gts4. Looking to push around 450 to 500 hp. what is the best ecu to use? Is there any that I can just plug and play that already has a good tune? I need help lol I dont know a lot about tuning cars....
Necromancer
At those goals, get a stand-alone. Although your expectations are high if you want to get that much power easily out of the RB20.
Reasonable numbers
You can do 370-400bhp safely. Just look at the following guide and it should get you there:
If you want more than this, replace the head gasket with a Cometic one, the head studs with ARP and get the rb25 turbo high flowed and you should be easily over 400bhp, maybe even around 425bhp or so...just a guess.
Also, go Nistune and you can get those numbers. Cheaper and easy to set and shorter dyno times because it has a base tune.
Nissan Skyline R32 GTS-T Tuning Guide
