1 - 10 of 10 Posts
just bought me a R32 gts-t with the rb20det engine earlier this week.
the problem with it is that it at low rpm (up till about 2000rpm) doenst run smooth.
the last owner did a compression test and said that cylinder nr 6 had lower compression compared to the other cylinders.
the engine does sometimes push out the oilstick and then spray through the "oilstick pipe" oil into the engineroom, the engine does also push small amounts of oil into the IC pipes and though the blowoff valve.
what might the problem be? blown headgasket? jammed/burned valve/valves? damaged piston?
the engine does exept bad idle run perfect without any bad sounds at all.
Discussion Starter · #4 ·
he he, too bad with that runaway pistonring.
i'm goin to check the compression on them and if there is a problem then pour a few drops of oil in that cylinder with bad compression to see if there is a piston or pistonring problem...
dude, yer fooked... the worlds gonna end!!!! hehe, im 99% sure yer rings knackered... replace asap.
1 - 10 of 10 Posts
