live fast die young
Hi there my rb20e has started to misfire when warm I've changed the plugs and still doing it can some one shed some light on this for me buggin me like made thanx dan
When was the last time the leads were changed? That would be my next port of call after spark plugs
Rb20e engine limiting at 3000 rpm and juddering like mad
Hi I have an rb20e engine and for the past week it has been playing up. It idles ok ish as soon as you put your foot on the throttle pedal it revs up to about 2500-3000 then it acks like it has a limiter on it, it's really doing my head in. I've changed the plugs, fuel filter, and dizzy cap, I know the timing belt is fine and all of the cylinders are ok it's intermittent . It ran fine for a day or so but not very good and now it's back doing the same I really need help has anyone had this problem and what you did to fix it many thanks Adam
Have you tried a known good AFM?
