Hi
Picked up a 2.0 litre non turbo R33 4 door from Wales on Thursday, 600 mile round trip, :crazy: car drives mint (pics to follow) just need to know the recommended oil grade so I can do a oil/filter change before the weekend.
Considering I'm used to the RB25DET in my Stagea I am impressed with the way it performs and as for the fuel consumption ...... :D
Your guna start collecting them!!! Something fully synthetic i'd say 10/40 or something? Or a similar grade as to what you'd put in any other 6cyl engine. In my opinion.
Just had a look in handbook and it says all gasolene vehicles including the RB20E contained 7.5W-30 (SG) oil when leaving the factory. Oil and filter change 4.2litres required.
ive been using a 10w40 semi synthetic oil in mine for well over 5yrs now and it gets changed every 6months,castrol also suggest gtx 10w40 oil...
Currently using Royal Purple 10W40 Full Synthetic Oil fantastic stuff! works great and you notice a difference between normal oil and the good stuff it makes the car a lot smoother and the engine a bit more responsive i found.
Man of many spanners
I honestly dont think you need to change the oil every 2500 miles with an n/a.
6000 miles should be enough
I've got into the habit of changing the oil on all our cars fairly regularly, we have a couple of kit cars which only do a couple of thousand miles each year so they get an annual oil change with quality oil as the summer approaches. I order my oil by the case when the rep calls at work, at the moment I've got 7 x 5L split between the various grades I use, as far as the N/A is concerned I might as well leave it that bit longer then.....
