hi ian,you need to take off all the pipe work above it but you prop have done that already,then you need to remove 3 bango bolts which are the water feed and oil feed one of which is under the turbo easier to get to from under the car move them out the way remove the bolts from the manifould 4 of,then remove your down pipe its easier that way only 3 bolts,then pull that bad boy out the way.oops forgot to say have a tray under the car to catch the oil from the turbo.:wave:
