1 - 11 of 11 Posts
could anyone PLEASE do a FAQ on this task ?? ( i dont have enough knowledge ).
i've seen so many different questions/answers ....
1. Do I have to change the head gasket - yes/no
2. DO I have to drill the block for oil feed - yes/no
3. what boost is good will all the bolt ons ??
4. Do I have to change the ECU ?? if so, would the DET ECU fit straight in ? ( R33 ).
5. ................................................
6. ...........................i am sure U guys have more questions ...........
7. ................................................
8. ................................................
together we can make it all clear i guess :)
confused.com
best person for the job would be lammy methinks.. then maybe get the mods to sticky the thread? tis a good idea..
Hi, Ive done 3 of these now so ill help lol, no the head gasket is ok as long as your not expecting 500+ bhp, if you look on the block there should be a 1/2 square plug that is your oil feed if it aint there you need to drill the block, the gtst ecu is a direct replacement but it WILL need mapping after its all bolted together...
seeking to be one of thee top DE+t conversions
just done this so look at my thread
1. Do I have to change the head gasket - yes/no NO
2. DO I have to drill the block for oil feed - yes/no NO, I HAD THE FEED AND I TEE'D INTO THE CAM OIL RETURN FOR THE RETUN FROM THE TURBO
3. what boost is good will all the bolt ons ?? THIS DEPENDS
4. Do I have to change the ECU ?? if so, would the DET ECU fit straight in ? ( R33 ). YES< A DIRECT ECU FROM A SPEC 1 OR 2 OR EVEN A COMPLEATLY NEW ECU...I HAD A SPEC 2 ONE NOW GOT A BLITZ
any more question give a a shout :D. Mine is running sweet
ok than - i've preety much known all the above answers ( just wanted some proof :) ).
the one i dont know is : DO THE LOOMS DIFFER ?? RB25DE and RB25DET ??
apart the boost sensor to the gauges ??
the thing is the guy that was converting my loom ( combined s13 CA18det and RB25de looms ) lost it $%^&*(........... i need to sort out a new loom and was thinking what to look for ( anyone could help on this ?? ).
I am going to be doing this in the next month or so (piecing together the parts needed). I was going to document it for people back home, but I'll probably post it up here for other people who may do the same thing (unless there is something similar already posted...?)
For people who may not know (including me)..are the stock ecu's tunable? I don't have much experience with Nissan's and turbo. The last turbo kit I did was on a Honda Civic and all I had to do was buy an ODB2B - ODB1 converter and an OBD1 ECU then could chip and tune to my hearts content. Is it the same with these ECU's?
confused.com
should we do this at different power levels.. say 300- 400 and 400 to 500 cos each is gonna be a little different
yeah :) we could make it with 2-3 stages...
with and without touching the internals ;)
350 bhp with a decent tune should be fine with stock DE internals ( above that some meth injection should come into play :) )
Auto Rocket
There is also some differences between car models R32, R33, R34 and engine series RB20DE, RB20DE NEO, RB25DE, RB25DE NEO, RB30E.
I just had my R34 25GT converted to +T so can help with info there.
I just had my R34 25GT converted to +25T so can help with info there.
hey bro i have a r34 25GT wanting to add a turbo...is it easy and reliable?
1 - 11 of 11 Posts
