1 - 8 of 8 Posts
Hi
What are the bigs cams you can fit in a rb25det gtst before you have to change the head to solid lifter?
Is it just the tomei poncams or can you go a bit bigger?
tit
Tomei ponscams mate. type A I believe.
I had type B sat about and couldn't drop them in without shimming and lifters and numerous other voodoo tricks :(
Type a and type b are used on the neo's i believe.
You want poncams with a 256 duration and a 9.5 lift.
Or you can get complete kit's with procams but this will require head to be stripped downand rebuilt with the kit.
1 - 8 of 8 Posts
