hey guys, new to skylines ! imported my 93 R32 GTST, RB25det swap in June. Has been running great up until about 2 weeks ago. I have been searching and searching and talking to many people and I can't seem to get this issue straightened out ...
These issues were only occurring randomly, didn't matter whether the engine was cold or hot. Sometimes at idle, the rpms will jump up and down, eventually the car will die unless I feather the gas constantly. Also, when driving on occasion in low gears up to third, it will hesitate and stutter when I try to give it gas and eventually catch. On one of the worst occasions, I had the pedal to the floor and the car wouldn't move for a good 3 seconds and then it would catch and lurch forward. The problem seeeeems to be getting increasingly worse but its hard to say...
Here are the things I have tried :
- Coil packs
- Fuel pump
- Spark plugs
- Fuel Filter
- Ignitor chip
- Fixed some cracked hose
- Checked for vacuum leaks
- Cleaned/replaced MAF
- Cleaned IACV
All of this lead to me thinking that my TPS was bad .... Well upon trying to adjust my TPS , I can't get the signal wire to read lower than .8 V ... and its supposed to be somewhere around .5 V I believe. But, when I put my boyfriends TPS off his car onto mine, it was doing the same thing where as on his car, it was adjusting fine. Which THEN lead me to believe my TPS wasnt actually messed up, because if I take my TPS off the throttle body, I can fully adjust the TPS to where it needs to be .... So with my TPS adjusted to the lowest it can go ( .8V ), when I start the car up it idles at 2000 rpm.
SO, I decided to check codes on my ECU ... I got 34 knock sensor and 21 ignition circuit ( but I think the 21 just meant that my battery is dying since I've had the ignition on and not started the car for a while )
ALSOOOOO, today we noticed that my coolant is foaming D:
My BOV is not atmospheric.
Can anyoneeeee please give me some insight ??? Maybe this is a plethora of problems ... wondering why they all popped up at the same time
- Coil packs
- Fuel pump
- Spark plugs
- Fuel Filter
- Ignitor chip
- Cleaned IACV
