1 - 1 of 1 Posts
Recently put 25det NEO into r32 coupe. After a multitude of wiring issues the car was running, not too badly either a standard 5psi without the factory bleed off solenoid, followed by fuelling issues (which ended up being intank pump was not filling surge tank...DUH!) all sorted, got fuel pressure now.
Now for the real problems the car running good (not great) for a good 10 or 20min or so. Then Dies completely whilst driving, no spark from what I can tell, originally told by sparky oh your external fuel pump has died. Not the case as surge tank wasnt filling! Then no hot start, maybe on occasion it would hot start. The next day fire up cold no problems. this went on for a couple weeks, not really driving the car knowing it has some kind of issue, then drove a further 18kms - same problem. No start hot again as usual, next cold start was sweet, it made a few sad cut out type things while idling COLD (never done this till now) turned it off and voila does not start again AT ALL!
FML ive spent massive amounts on this project was supposed to all minto after last trip to sparky but now no one wants to know about it. ANY insight would be greatly appreciated as im totally baffled as to how it can go from running quite well to not at all with no external interferance!
1 - 1 of 1 Posts
