1 - 20 of 22 Posts
As Above
Was driving today the car was fine, came to a give way and i could feel it missing slighty. Pulled up at a mates, went for a brew. Came out and tried to restart car and it was mising badly and smoking like a train. Drove it home and it cleaered. Just been out in it and its the same and struggles to turn over now. Worrying about it. May have to go now
Any Suggestions be very helpful
Totaly standard
sliding like your mum
Struggling to turn over would say to me its trying to hydraulic from coolant leak into a cylinder eg headgasket. Try running with rad cap off and see if the coolant is bubbling. Or get a compression test done. These would be my first checks from what you described :)
Excess pressure in rad would push coolant into header still pointing at head gasket etc
Was thinking on a headgasket to, suggest you do the tests that paul describes and dont drive with it anymore.
Are you in the AA/RAC etc?
Cupla hundred quid to do
Discussion Starter #12
Yeah mate in aa with home start, might give them a ring tomorrow. I can pretty much to everything to a car never done a head though, easy job?
Sent from my GT-I9300 using Tapatalk 2
AA can do a headgasket check on the roadside if you call them out, rules out one possibility then!
Discussion Starter #14
That's be ace mate, I'll give them a shout tomorrow morning.
When I turned it of it was still smoking/steaming too
I wouldn't run it until you get it checked out properly bud, a hydrolock can be a massive headache!!
Discussion Starter #16
Will the aa be able to tell easy with there test? It runs smooth until warm and start missing and smoking
Yes mate the AA will be able to tell you in 2 minutes, they literally do a sniffer bottle test on the rad to check for exhaust gasses in the coolant. Mega simple test.
brett
a hydrolock can kill a engine.i wouldnt advise you keep running it if that is the case.new headgasket kit £140,head bolts unless you reuse the old ones and labour so your talking £500+ if the head itself is ok.
Discussion Starter #20
im not going to use it, got AA come to take it to a garge on thursday, Cant decided if to keep or sell it now...
1 - 20 of 22 Posts
