1 - 20 of 202 Posts
NBOOST
A few seam to be interested in this so I'll give it a go.
This is what it started off as
Z32 AFM,
RSP 450 Turbo,
Hybrid GT Racing FMIC (780mm x 295mm x 78mm),
HKS SSQV,
Jun Style Inlet Manifold,
Plateau Honed Bores,
Fully Balanced Bottom End (With Clutch),
86.5mm Wiseco Forged Pistons,
GTR OEM Rods,
ACL Bearings,
Tomei Con Rod Bolts,
ARP Head Studs,
N1 Oil Pump
JUN Extended Oil Drive Collar,
N1 Water Pump,
RIPS Extended / Baffled Sump,
Oil Catch Tank,
ATI Damper Pulley 1000hp rated,
Power Enterprise 550cc Injectors,
Splitfire Coil packs,
HKS 1.2mm Head gasket,
Tomei Pon Cams (256 IN/EX, 8.5mm Lift),
Tomei Adjustable Cam Pulley (Exhaust),
Tomei Timing Belt,
Z32 Ecu with Nistune Daughterboard
19 Row Oil Cooler,
Z32 ecu has now been replaced with a Link G4 which I had idling on the above setup perfectly.
So far I've got an S-Tec manifold, S-Tec Wastegate, Holset HX35/40 hybrid and a divided transient T3/T4 adapter
I've already port matched the manifold with it being RB20/25/26 fitment the ports were out slightly.
Test fitted them tonight to see how bad the wastegate port interence was, these manifolds are supposed to clash with R33 chassis legs. I must be lucky, mine looks like I'm just about going to have enough room.
I've also been lucky with the turbo and cam cover clearance, if it wasn't for the T3/T4 adapter I'd be hacking chunks out of the cam cover.
Exhaust isn't going to work out how I wanted it to though, I was hoping to be able to use the standard downpipe and just make up a new elbow but the wastegate is now sat right where the downpipe used to come into the engine bay.
only just spotted this thread mate! thats coming along for ya :)
when I had my downpipe made I had to send off my turbo n manifold - they then jigged it up and made a downpipe which took the ext wgate into account for me so mine came back a bit more plug-n-play
will be keeping my peepers on this thread ...the top mount skyline crew grows :dogpile:
NBOOST
:dogpile:
DIY start to finish, ordered all the pipe on saturday so should be able to get something fabricated this weekend :D can't believe the custom exhaust places in my area don't stock manderel bends :gay:
Everything in the pic got removed though on saturday as it was just test fitted. It's now all bolted back up with gaskets etc. clocked the compressor housing on the turbo to line up with my cooler pipes, fitted my oil feed and linked the water pipes up as they are no longer needed.
Exhaustsuk over at sheff could have prob fabricated something up for ya. Though your then messing about trailering the car about i supose.... Looking good either way, what kinda power figure you aiming for??
Had a exhaustsuk system on my old laguna, needless to say it out lived the car lol
looking good. read allsorts about holset and i duno what to make of them. was going to put one on my 14a but after reading they are laggy and as they come off diesel buses etc they arnt right for smaller litre cars! so as this is hybrid whats been done to change it? i use my car for drifting so need boost there without silly lag, but like the idea that they cost very little compaired to HKS etc and make big power achievable to people on smaller budgets! keep my eyehole on this thread :p
Jay
NBOOST
S-tec stuff looks very good quality, it's got decent thickness walls on the piping and it weighs a fair bit unlike the ebay jobbies that feel like your picking up a roll of tin foil.
A few people on here have got them, Bruce-m that I can think of off the top of my head, if you look in Bruce's project thread you can see quite a few pics of his being fitted at RSP and the wastegate piping being altered which for some reason mine has clearance.
They are universal fitment for all the RB engines so you have to port match it but if you've got access to a decent die grinder then it's an easy job to do.
I've read their site and its all 321 stainless, so it should not crack! I've also seen the review below:
http://soldave.ismysite.co.uk/biginjapan/s-tec-motorsports-manifold-review
Very useful, did you clean up the inner collector welds ?
Did you buy it direct or off bruce? I think his was modified due to the wastegate used, not the standard one S-tec provide, its a HKS copy the S-Tec one if I'm right.
Looking like with the new ECU and turbine set up you'll be good for the 500 mark, is that the goal?
How much it cost you in total with import / vat etc? did you get it during november/december when he had the sale on? Sounds like a good one then... you'll have to let us know how you get on once its all done, see how it holds up after some hammer.
I meant 500 ATH :)
NBOOST
Discussion Starter #14
Done a few hours today. Finally managed to get hold of some exhaust pipe from a local company, the place I ordered it from originally 2 weeks ago still hasn't got any pipe in, not bad to say they make custom exhausts for a living and they haven't got the basics in stock.
Oil return pipe fabricated, it's very close to the manifold so I decided not to risk rubber pipe and put this together to clear the manifold
Main exhaust pipes on, still needs chopping and a flexy welding in and a lambda boss then pipe the wastegate into it
Fingers crossed I might get to a stage where I can start it up tomorrow.
Wow Andy your really flying through this! Are you gonna run screamer or plumb ext wgate into downpipe like mine does?
Also will you be putting a boss in th downpipe for wideband sensor?
What ecu you got planned?
Also are you gonna be running non afm?
Really impressed.. wish I could have done th pipework all th way on mine but can't weld!
Lovin th oil return.. very similar to mine!
Oh you gonna stick an egt sensor in manifold?
Bein nosey lol
NBOOST
Discussion Starter #16
This sunny weather has given me a kick up the arse to get on with it
Ye it's getting plumbed back in, I don't like the noise screamers make
Going on tomorrow, didn't fit it today just incase the positioning of it gets in the way of something I do tomorrow.
Link G4 already fitted
Sold it already :D
EGT sensor can be seen on the last pic tucked in the white wire for the timing light. I snapped the fixing union for it today though so need to get a new one tomorrow
Bein nosey lol
oh and parcel force sent me a customs invoice today, looks like my 750cc injectors have arrived
This also arrived the other day
NBOOST
Discussion Starter #18
Had a steady afternoon in the garage finishing what I started yesterday.
Exhaust elbow and downpipe finished. Next job was to start butchering it for the bottom pic
Wastegate routed back into the downpipe, got to wait now and see if the flexi joint I've ordered fits into the small section of straight pipe or it's going to have to go on as it is.
Now I know why it costs so much for a custom exhaust, it's taken me 4 hours just to make the wastegate pipework up constantly bolting stuff up, marking it, removing it, cutting then bolting it back up etc.
I'm stuck now until I get the flexi joint and fingers crossed I've got room to fit it.
.......P33 TEX.........
This is goin to be immense! Can't wait to see the graphs after its been on the dyno!
Good luck, just keep thinkin of the end result! It Wil all be worth it
nice work Andy - I dont have a flexi section on my downpipe - I did want one but the welders couldn't seem to figure out where to put one in.
heres mine:
I'm not sure if I could add any flexi section in mine tbh - probably underneath were it connects to the exhaust midsection maybe.
nice work tho - your really powerin on with it - btw car in the background looks ace with that kit n wheels!
1 - 20 of 202 Posts
