If you are still using maf sensors then you will need the standard one or the z32 if you want upto around 500 bhp.
What ECU do you have?
+1he only wants 450bhp bruce even with that turbo. it will be soo laggy its unreal
i think you mean unless he's running an ECU that supports a MAF sensor (i.e HKS f-con) then he'll need the AFMIf you are still using maf sensors then you will need the standard one or the z32 if you want upto around 500 bhp.
