1 - 3 of 3 Posts
I just replaced the head gasket on this engine. I accidentally started the engine without priming it. After the start up, it immediately developed this nasty valve train noise. Does anyone know where is the noise originated from and how to fix it.
Here is the youtube video
Thanks!
Did you remove the cams and followers? if so could be a follower not pressurizing.
I did not remove the camshafts or the followers for the rebuild. But, I did remove them after I had this noise issue to check if they were good. They seemed to be OK with some having small light scratches on them.
1 - 3 of 3 Posts
