1 - 2 of 2 Posts
can some one give me some advice on my r33 gts-t ive just changed the rear and front bushes as they were worn to poly bushes i took the car to be laser tracked but the o/s rear camber will not go out enough its 2 degrees out of line does any one know what could cause this all the wheels need doing but unless i can find out what the problem is they cant set the car up i would very much appreciate some advice please
check to male sure you have no suspension damage or anythings bent mate and is your car lowered??
1 - 2 of 2 Posts
