1 - 8 of 8 Posts
I UNDERSTAND GTSBOY BLANKED THE RECIRCULATING DV FLANGE ON HIS R32, CAN THE SAME BE DONE ON THE R33 OR HAS ANYONE DONE THIS ALREADY ?
It can be done.
STOP SHOUTING!!!!!!! There is a CAPS LOCK key somewhere on your keyboard. If you are on a mobile or summit then I do apologise.
GTST-LAD did it with his R32, you need to play with some of the piping I think. I intend to do it to mine at some stage, so will be searching for the thread soon.
Unfortunately, it will be hard to find in a search as I can't remember the thread title.
The thread you need is "stock bov bleeding air".
Is the layout same in R32 as R33, I don't have a manual yet to check on.
G
pipe 1 comes from the plenum , underneath it " on the plenum ", comes pipe 2 , on mine this has a t piece one bit goes 2 carbon canister , other goes 2 the blitz , i reckon , that u remove pipe 1 and run this 2 the blitz , and take all the other stuff off , and block holes , flange etc up.
G
stalling , yes i have heard this
may be this is why the japs dident do this , and the blitz is just for show " eg waste of money "
thanks Nismo a good 2p worth
1 - 8 of 8 Posts
