Hello All
Start of MANY questions about my new purchase....sorry.......
Can you replace the ECU in the Automatic R33 GTS-T for a performance version?
Know the manual ECU are a stright swap out but the automatic ECU has the additional cable/link to the Gearbox ECU (drivers side foot well)
Also will the ECU need to be HICAS aware as yes mine a HICAS auto :)
Ta,
DS
Hi and welcome.
The answer is yes. However there is a caviat with that. you are severly limited to just one or two replcament ecu's.
I know that ont of the HKS ECU's (HKS F-Con i think) will do automatics (its something to do with changing gear, the gearbox makes the ecu adjust something when changing).
Hope that helps.
John
greddy do a piggy back one that will work on a automatic :)
confused.com
links also make one im told....piggy back type
