i hate ABS, too interfereing, but thats my opinion.
not a clue mate. should ther be any difference in pedal feel braking distance etc?standar servo will be fine mate why change it?????????????????????
no mate the servo will work regardless of whether the car has abs or not just means once you remove the abs if you stomp real hard the wheels will locknot a clue mate. should ther be any difference in pedal feel braking distance etc?
wardy
your right mate im not 100% tonight so :sorry:thats the master cylinder isnt it?? not the servo??
erm.... thats what your supposed to do when the wheels lock up, feather the pedal... with abs you put your foot down more, but its a pain in the hole when late braking because it wont let you brake as hardMy 33 has no ABS and was really treacherous in the snow we had recently. Although you could always simulate abs by tapping the brake pedal really fast!
no it kicks in earlier than the limits of the car,Yeh that's what I meant, can feather the pedal to stop skidding around in the snow
No abs better for late braking technique? Always thought abs would stop you faster no matter how you brake, no?
no the case,if you think about how abs functions it means that the brakes are never working as hard as they can,the abs keeps braking in a safety zone away from locking,if you can get your brakes to the limit between force and grip you will stop a lot quickerNo abs better for late braking technique? Always thought abs would stop you faster no matter how you brake, no?
so if i was to remove i would need a master cylinder from ?no mate the servo will work regardless of whether the car has abs or not just means once you remove the abs if you stomp real hard the wheels will lock
however i realise now that due to abs your servo will have 2 pipes coming out to abs unit
you will need one with 4 pipes coming out
