basically got everywhere out the way removed all the bellhousing bolts even the top ones and the starter motor bolts. i cannot get the box off no matter what way i push or pull. every bolt now removed... there any good tips or how to do.
need this box off lol. gonna start bashing the sh!t out of it lol. Only joking.
seriuously tho guys any help would be good greatful
dave
You know it's a pull type clutch right?? You need to disconnect the clutch fork before it'll come away from the clutch and engine. You'll need to take off the slave cylinder off the box, get a look in there, use a screwdriver to pull out the R-clip that's holding the fork pin in place then push the for pin down through. Hope you're pulling engine and box together or it'll be a bit of a nightmare to get back together. Hope that helps.
