Track car.
I'm having the car fully caged very soon, and its going to have a posh custom weld in multi point cage that is welded to the pillars ect.
My question is, and before you shoot me down in flames i totaly understand the need for it and the very thought is a bit of a concern, but i'm going to ask anyways
If i completely remove the rear bulk head and speaker shelf, cut it out back the were it joints on with the spot welds, and then have the cage put in and brace it so its the same if not better then the shelf...
Do you guys think it would be ok ? I know these skylines flex so much, so the car is fully seam welded (properly
Just interested on peoples views and if anyone has done it and what were there findings.
Tbh, i'm not removing it for weight as i don't care about the weight because the power it will be running it will not make much difference, and its not like i'm going for quater mile times, not to mention the cage will take it over the stock weight i'm sure
Look forward to see what you guys think.
Ta, clarkey-san
Ta, clarkey-san
