Hi, usually people take it to mechanics and i have been quoted 700-900.
They take the head off, machine it etc as it will most likely be warped, make sure there are no cracks in the block and then replace the gasket and put it all back together, there might be coolant in the oil or oil in the coolant or both so you have to flush both systems too, many hours of labour mainly. Im sure if you were to try it yourself it wouldnt be hard but the thing is you may need to machine the head.
Someone who's actaully done the job may be able to help you on the DIY approach.
Hope it helps.
Hope it helps.
