1 - 14 of 14 Posts
i done black wire earth trick fantastic superb improvement,reset ecu sadly two days later....
this morning went to start car hicas light on steering heavy,gone to work parked up 8hours later started car no hicas light car driving normally,came home turned car off/on hicas light back on steering heavy?? now the hicas light has developed a mind,i noticed before it used to come on and go off after i turned the ignition on, but now doesnt go off after ignition key turned but goes off when started..ie normal. stays on...ie heavy steering??
i checked all fuses power steering fluid now im puzzled??
help me if you can many thanks.:cheers:
Is the fact that the HICAS is on is what makes the steering so heavy? My HICAS light stays on when the car is running and the steering is crazily heavy...
yes i get a heavy steering with hicas light on,when i wait 3 seconds light goes out but i need to find a solution not a quick fix has anybody had this problem and actually fixed it all replies appreciated thanks:cheers:
when u reset the ecu did u make sure ur wheels were exactly straight as sometimes this can mess up the hicas.
So try resettin it again and this time make sure ur weels are exactly straight hope this helps
Cheers Chris
thats wot i was gona sugest as i had probs with mine i just disconnected battery re connected and job done (wheels straihgt)
yes i checked wheels and reset it,funny thing is the light goes off after the cars had a break i checked a few posts here and weak battery seems to be a cause considering mine is tiny and im running a 2000watts system 4 speakers and 500watts rms subwoofer duh? i not use system couple of days and see how it goes:cheers:
i done that too luckily for me i found a local specialist garage who have nissan diagnostic tools,so i can get her wired if i absolutely have to in the end.people who live near pro garages i dont think realise how lucky they are.true there arent many nissan pro garages up and down the country,this is why im learning so i dont get ripped off,because you can go some places and they know youve just walked in to get f**** !! i have learnt if you have a skyline you must learn the very basics at least.:cheers:
damn damn it just repaced standard battery with big onereset ecu all precuations taken still fookin hicas light??
after doing second stage mod black wire do you think its confused the ecu peeps??
Number 1 Monkey
Discussion Starter #12
i will try resseting the ecu one more time and this time put the lights on to get rid of all electric when disconnecting battery,if this fails its going for a diagnostic,il let you know how i get on:cheers:
Discussion Starter #14
i took it to nissan stourbridge who charged me 85 quid to tell me its duff alernator,got it recondition 50 quid prob sorted,fair price for a test everything else oky.)
1 - 14 of 14 Posts
