1 - 3 of 3 Posts
Approx [email protected] bar
I have purchased a tacho/rev counter for my R32GTR.
I need to locate a coil negative wire for this.
My car apparently has R34 coil packs on it.
I believe the coil wires basically come out of the back of the engine at the top - can anyone tell me which one to put the rev counter to please?
Thanks:D
re taco
you can not pick up froma coil wire as the spark only fires 1 in 6 times therfore you taco wont read correctley
at the back of the block on a skyline you will find a white loop of wire this is used to run a timming light
i think you amy be able to use this if not
may be the back of the o/e taco
i would sugest you get in contact with a skyline tunner eg abbey motorsport .
ta ian
1 - 3 of 3 Posts
